Is it possible to install doors on the open shelves that go all the way up to the ceiling? Please see the attached picture for reference.
Hi @joabi,
Yes, it is possible to install doors on the open shelves shown in the picture, even though they extend all the way to the ceiling. The space is actually well suited for a built-in cabinet or pantry-style finish. Depending on the look you want, you could install full-height hinged doors, split the opening into upper and lower doors, or even use sliding doors if space is limited. The main thing to check is whether there are solid side panels or framing available for mounting hinges, as plaster walls alone may need additional support. The frame would usually include two vertical studs, one on each side, a top plate fitted tightly against the ceiling, and a bottom plate fixed at the floor.
Because the doors would be quite tall, it is also important to use quality hinges and allow a small amount of clearance near the ceiling for installation and smooth operation.
With the right measurements and fittings, the shelving could be enclosed neatly to create a clean, modern storage area. Here's an AI rendering of what it could look like. Please let me know if you have any questions. Mitchell
Just wondering whether you ended up moving forward with adding doors to the shelving.
That space looked like it had a lot of potential for a really clean built-in look, so I’d be interested to hear which direction you ended up taking and whether the AI concept helped with the planning side of things.
And if the project’s still in the planning phase or you ran into any issues around framing or hinge mounting, happy to help further.
Hey Mitchell,
I’m actually looking for someone to do it for me since I don’t think I’ll end up doing it myself.
I still like the built-in look idea, but I’d rather get someone experienced to handle the doors and fitting properly.
If you know anyone good with custom cabinetry or built-in shelving doors, I’d definitely be open to recommendations.
Also, if I go with option 1, would I still need to add a frame around the shelving?
Thanks for checking in though, I appreciate it.
Hi @joabi ,
That’s completely understandable. Something like this can definitely be worth getting a cabinet maker or carpenter involved with, particularly if you’re after that clean built-in look.
If you’re in the Sydney region, you could look at using the Bunnings Services Marketplace to source someone suitable. Otherwise, platforms such as Hipages or Airtasker can also be good for finding local tradespeople experienced with cabinetry and built-in storage.
In regard to the frame, you may not necessarily need one, but it does make things easier. It provides a solid and consistent fixing point for hinges and also helps true up the opening, as walls are not always perfectly straight or square. Without a frame, getting the doors to sit neatly and maintain even gaps can sometimes be a bit trickier.
