Hello bunnings team, I am wanting to install a Twinwall Polycarbonate Roofing, using the material from your supplier Sunpal.
As I was trying to create a shopping list of the material needed, I noticed that Bunnings doesn't sell all of the material required (even though Sunpal/Palram in their installation guide requires all the material, which doesn't make too much sense... (see screenshot or link below).
https://www.palram.com/au/wp-content/uploads/sites/3/2019/07/SUNLITE_Installation_Guide_87734-13-02-19.pdf
Also, Bunnings seems to be the main purchaser of Sunpal's material. My question is, how can I get the all of the equipment through bunnings? I tried to ask the person at the special order desk, although the person was a bit clueless unfortunately, and only informed that I couldn't order anything without an I/N number.
The material bunnings don't sell are/that could not be found on your webpage are:
F-section
Blocking tape
Breather tape
(see pic of material attached) - all very important material to build this yourself… So how can I order this through bunnings?
The things Bunnings does sell for this is:
Suntuf 3.0m Anodised Sunlite H Joiner Cover I/N: 1010570
Sunlite 3.0m Anodised H Joiner Base I/N: 1010569
Sunlite 15m Suntuf Wedge Gasket 2 Part Joiner I/N: 0074787
Suntuf 3000 x 45 x 20mm Surfmist Back Channel Frame - Surfmist (2) I/N: 1010802 (white)
Suntuf 3000mm Sunlite 10mm Aluminium Sheet End Cap I/N: 1010571
Sunlite Aluminium End Cap Lock 16x65mm I/N: 1010988
Thank you for your help!
