Hi
I bought Holman pure flow flexible water hose that comes with a fitting to connect to the recycle water tap.
(Another photo in below thread)
I threaded it anticlockwise and it is not threading in. Clockwise does not help either. Rather it is threading at an angle. I stopped, thinking it might damage the thread in the plastic fitting.
There are only 2 circle of threads in the recycle water tap.
How to fit the plastic fitting correctly. Should I tape (Teflon) before threading in. Any suggestions?
I tried with another recycle water tap on another side of the home and it is the same.
Appreciate your advice.
Thanks
MM
