Dear community,
I’m starting to plan a DIY composite deck for my backyard. The area is approximately 3.7m × 6.8m. I’ve been researching the tools, materials, and steps involved, but as this will be my first time building a deck, I’m feeling a bit overwhelmed and would really appreciate some advice before moving forward.
The existing ground is sloped and mostly concreted, with the outer/lower side paved. The right side is about 45cm higher than the left side, while the inner side near the house is around 20cm higher than the outer side.
My main questions are: Would adjustable pedestal feet be suitable for this type of sloping surface and able to achieve a level deck? Or would there be a better structural solution for this layout?
I also have some recycled timber salvaged from my demolished garage. The timber is classified as H4 or H5 treated pine. I’m considering reusing it for the joists/frame — would this be appropriate? If not, would you recommend a timber frame or a metal frame instead? The deck will be under a patio and attached to two walls of the house, but it will still be exposed to rain and lawn irrigation.
Any advice or practical tips regarding framing, levelling, drainage, or general considerations for a deck of this size and site condition would be greatly appreciated.
Thank you in advance!
