Looking for tips to patch up this hole in the cornice (left by an old foxtel connection). Cornice is plaster. Thanks in advance
Hi @HReno,
This hole is a little large to purely use filler on its own. You could try building up the edges in several thin coats, letting each coat dry properly in between. Over time you’ll be able to bridge the gap, then sand it flush before priming and painting.
A couple of easier/more reliable options though:
Once filled:
Using a lightweight patching compound topcoat for the final coat will usually give the best finish.
Here's a helpful step-by-step guide: How to fill a hole in plasterboard.
