Hi!
Both the heat bulbs have died in my bathroom, is it possible to replace these bulbs?
And if I can, what kind of bulb is best?
Hello @AnnaB
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your heat lamps.
Printed on the surface of the lamp or on the side of the steel thread is the wattage of the lamp. I propose bringing one of the busted lamps with you to the store and get a similar model. A good example is the https://www.bunnings.com.au/hpm-275w-es-heat-lamp_p4441725 it comes in a higher wattage, but it's best to get a similar wattage to the one that you have.
The general step to remove the lamp is to unscrew it anticlockwise and clockwise to screw it back on. Please be careful with the lamp as it is fragile and is easily damaged.
I recommend having a look at this guide if you are using a ladder -
Hi @AnnaB ,
Just checking in to see how you ended up going with the heat lamps. Were you able to source replacement globes and get everything working again?
Hopefully, the advice above helped make the swap over straightforward, but if you ran into any issues along the way or still need a hand identifying the correct lamps, we’d be more than happy to help further.
