I accidentally cracked the glass vanity sink in our bathroom. Is it possible to fix this with epoxy/gorilla glue? Any thoughts/advice would be very appreciated.
Hi @enaiduj,
Unfortunately, once glass has cracked, there isn’t a reliable permanent repair option. Products like epoxy might temporarily hold the crack together or make it less noticeable, but they won’t restore the strength of the glass.
For this reason, unfortunately, I would suggest that the only long-term solution is to replace the sink.
You might like to check out our range of https://www.bunnings.com.au/products/bathroom-plumbing/bathroom/vanities-mirrors/bathroom-vanities to see what you like and consider options for replacement.
If you were just looking for a short-term solution, then you could try applying some https://www.bunnings.com.au/gorilla-25ml-clear-epoxy-glue_p1230178 to the crack, but there are no guarantees it would stop the crack from extending further or ensure that the sink continues to hold water.
