Hey,
Is there a way to fix missing grout gaps like this? Or do I need a professional in? Floor under a cupboard
Hello @melrane
Thank you for sharing your question about your grout fill. Yes, you do have the option of getting a professional to regrout your floor gap. However, you can also explore the option of repairing it yourself. The old grout can be removed using a https://www.bunnings.com.au/qep-professional-grout-saw_p0393523 or use a flathead screwdriver to lift up the loose grout.
To fill the gap, I suggest using https://www.bunnings.com.au/sika-300ml-white-sikaseal-kitchen-and-bathroom-silicone-sealant_p1210308 . Sealing the gap with silicone means that it can accommodate movement and will not crack or fall apart when it occurs.
Here is a handy step-by-step guide: How To Silicone Seal A Bath (the techniques used are applicable to your project)
Please remember to wear personal protection such as gloves and goggles when working on your project.
