Hi Workshop peeps,
I'm doing some renovations on my place and need to replace some strike plates in the door frames. The home was built in 1995 and the door frames are metal so I need to find strike plates the same size as the originals so that they fit the existing rebate.
The plate size is 68mm long x 48mm wide with the holes about 53mm apart. I've searched Bunnings stores and extensively on the Interwebs but can't find this size anywhere. Most are either 70mm or 60mm and the screw holes don't match up. I'm pretty sure these must have been standard at the time and must be in tens of thousands of homes in WA. Why are these so hard to find, does anyone have any ideas where I might find some?
