Nice to meet you all, would like to get the best suitable filler to repair the external wall crack, which wall filler do you suggested? or do this crack comes from structural problem? Thanks, Alex
Hello @alex617
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about repairing your render.
It's definitely a possibility that the crack was generated from structural movement. These movements thought minimal does have an effect on the outside covering of your home. It only becomes a bit of a worry when the crack or movement becomes large and exaggerated. The general steps to repair are to clean the crack with a stiff bristle brush to remove any loose dirt and debris. Once the crack has been thoroughly cleaned, I suggest using https://www.bunnings.com.au/polyfilla-500g-exterior-brick-and-render-masonry_p1210565 . I also recommend having a look at this guide - How to repair a rendered wall by @Nailbag.
In the interest of long-term repair, I suggest keeping an eye on the wall crack and any other signs of wall movement around the area. Should new cracks appear it would be a clear indication of larger movement in your wall that might need to be addressed.
Let me call on our members who have done repairs on their rendered wall @diynewbie1, @Benny3 and @ChrisA for their recommendations.
Please remember to wear personal protection such as gloves, goggles and a mask when working on your repairs.
