I have a shower head rail that the wall anchors have become loose and pulled out of the wall. I want to know how I can repair the hole and if I can use the same location for mounting the shower rail again?
Is there a filler that I can the redrill to insert an anchor? I suspect that I will need to drill a bigger size than previous as the first installer didn't use an anchor and drilled then screwed directly into the wall. If I need a bigger hole, do I need to use a specific drill bit so as not to damage the wall tiles?
TIA
