The lock has a lever and a lock lever (that is lockable). The lever goes to the closed position when the door is closed and then the lock lever can be engaged. However the mechanism is damaged and I need to replace the whole lock. The inside and outside handles are also worse for wear so a complete lock set would be good. I have removed the handles and lock barrel but can't pull the lock part that fits inside the door out because it appears to be hooked to something above and below it inside the door. Can I do this myself?
