Has anyone installed the cistern pictured without a plumber? Not knowing what theyre doing or is it definitely a job for a plumber? π
Hello @Laura298
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your toilet cistern.
Please note that plumbing work needs to be completed by a licensed professional for safety and compliance.Β
Thanks for the photo and for explaining what youβre looking to do. Connecting or modifying plumbing for appliances such as toilet suites is considered regulated plumbing work. Any changes to existing pipework, fittings or connections need to be carried out by a licensed plumber.
A plumber would be able to check your current setup and advise on the most suitable way to install the cistern safely and in line with requirements. I would advise engaging the services of a plumber to install your cistern.
Thanks for your reply Eric.
I would also like to suggest having a look at our https://www.bunnings.com.au/services/in-home/toilet-installation service should you decide to replace your entire toilet suite.
