A mate had an old bath he was willing to give me - made it into our all year round soaker by connecting to laundry trough
https://www.workshop.bunnings.com.au/home/leaving?allowTrusted=1&target=https%3A%2F%2Fwww.bunnings.com.au%2Fshaw-mason-chrome-bath-spout-diverter_p0595270
3x
https://www.bunnings.com.au/kinetic-2m-stainless-steel-shower-hose_p4920458
2x
https://www.bunnings.com.au/brasshards-15mm-brass-threaded-hexagon-nipple-lf_p0572462
https://www.bunnings.com.au/kinetic-20mm-brass-back-plated-tap_p0499637
Brackets to connect hose to wall
For drainage:
https://www.bunnings.com.au/ki-carma-20kg-10-20mm-drainage-gravel_p3460052
https://www.bunnings.com.au/reln-stretch-ag-pipe-100mm-x-8m-slotted-and-socked_p4770281
Plus fencing materials
Pliers, drill, spakfilla,
Disconnected old laundry tap, put in new spout with diverter
- Step 2:
Connected shower hose to new spout, drilled hole in wall and ran hose through
- Step 3:
Connected up next two hoses to each other, mounted up across then down to bath area using small brackets
- Step 4:
Connected end of hoses to new tap, put it as far as it would go towards middle of bath then screwed new tap in.
- Step 5:
Spakfill gap around hose leading outside
- Step 6:
Dug ~6m trench for drainage with big rock filled hole at the end (along tree line - bonus hydration for ornamental pears!). Added rocks then laid ag drain, topped up with rocks then put soil on top.
- Step 7:
For bath, just run water in laundry tap til it's a good temp, then divert to hose. Once bath is full, turn off cold water and just run hot (since it's the only water you'll need from there on).
