Hey there, we have a 50cm deep gap between the deck and our neighbours property (with not much of a retaining wall) the land on our house must've been cut after and the fence is quite old so must've existed already. This same gap can be seen across the perimeter as well (between our sideyard grass and other neighbours fence) Is there much we can do with this other than filling it up with gravel and stones? been struggling to figure out how to go about it. The issue with talking to the neighbours about a new fence + proper retaining wall is that there would be 3 neighbours we have to consult since we have quite a wide block 😂 and I really don't want to spend the money on that.
Welcome to the Bunnings Workshop community @jattkaim. It's a pleasure to have you join us and many thanks for your question on fence gaps.
What stands out is that there appears to be a significant difference in ground level between your property and the neighbouring properties, with the fences sitting lower than your side. Neither timber nor Colorbond boundary fences are designed to act as retaining walls, so filling the trench and allowing material to press against the fence could shorten its lifespan or potentially cause it to fail over time.
Before considering any structure along the boundary, I'd recommend checking with your local council regarding any regulations on building near fences and property boundaries.
Some alternatives you might consider are:
From the photos, it looks like the gap may actually be performing an important drainage and separation function, so I'd be hesitant to eliminate it entirely without first determining whether any retaining structure is required.
Once you've checked in with council, if you are able to build closer to the fence, creating raised seating benchs on the top of the retaining wall could help minimise the gap and also provide a functional seating area. Here are a couple of AI-generated images for some inspiration. Let me tag @J-P to see if they have any thoughts.
@jattkaim - agree with what @MitchellMc has suggested. You can opt for ground cover succulents or artificial grass if you prefer green. Keep in mind ground cover succulents needs regular (once in a quarter) maintenance so that overgrow.
Thanks @MitchellMc @J-P I will probably chat to the neighbour who does have a colorbond fence at the moment to increase the height of the retaining wall, as that fence currently does also need some repairs. But the drop off for the other sides isn't as bad. Confirming that the alternatives you have suggest all would require chatting to council right? I think a mix of the decorative gravel & bench sounds like a good idea for sure.
Hello @jattkaim
Yes, it would be best to check with your local council regarding any regulations on building near fences and property boundaries.
Please keep us updated with your progress, we look forward to seeing the start of your project.
