Hello! I'm seeking some advice on the best approach to managing an exposed brick wall inside a cupboard.
I had plans to redo the whole cupboard, and in that process discover a large empty cavity at the top of the cupboard which could be used for extra storage. I've since decided not to redo the cupboard, but now have a hole in the cupboard ceiling (leading to the cavity) that I need to address.
Ideal solution: remove the whole cupboard ceiling, deal with the exposed brick, use the space for extra storage.
The exposed brick has crumbling mortar, and the actual ceiling is a timber panel, which I assume leads to my upstairs neighbours floor. As its inside a cupboard, its not the most accessible (but not impossible). I'm not worried about aesthetics, just want to ensure that belongings are protected from dust and moisture.
Looking for a cost and time efficient option. Am I better off just replacing the original cupboard ceiling and hiding the cavity away again?
Thank you!
