I wanted to make better use of the narrow side passage between my house and boundary fence. Instead of leaving the area unused, I explored several canopy designs that could provide weather protection and create practical storage space for tools, outdoor equipment and household items.
The project compares four different construction methods suitable for various side access widths and site conditions, including narrow passages, wider spans and sloping fence lines. The goal was to maximise storage capacity while maintaining ventilation, drainage and easy access between the front and backyard.
• Treated pine or hardwood timber posts
• Timber ledgers and roof beams
• Polycarbonate roofing sheets
• Corrugated metal roofing sheets (optional)
• Aluminium U-channel track
• Fence post mounting brackets
• Galvanised angle brackets
• Roofing screws
• Masonry anchors
• Silicone sealant
• Residential guttering
• Downpipe components
• Concrete pavers or outdoor paving
• Cordless drill/driver
• Impact driver
• Circular saw or drop saw
• Spirit level
• Tape measure
• Speed square
• Clamps
• Ladder
• Caulking gun
• Tin snips
• Socket set
• Pencil and marking tools
• Safety glasses
• Hearing protection
• Work gloves
Assess the Side Access Area
Measure the available width, length and height clearance of the side passage. Check fence condition, house wall condition, drainage fall and any obstacles such as air-conditioning units, hot water systems or downpipes. This helps determine which canopy design is most suitable for the site.
- Step 2:
Choose the Canopy Design
Compare the four canopy options and select the most appropriate design based on passage width, roof span, drainage requirements and wind exposure.
- Method 1: Minimalist Track-Rail Design
- Method 2: Dual-Ledger Design
- Method 3: Reinforced Cross-Beam Design
- Method 4: Reverse-Slope Design
- Step 3:
Install Fence-Side Framing
Position timber posts in front of existing fence posts and secure them using fence post mounting brackets. Install the horizontal fence-side beam and verify alignment with a spirit level.
- Step 4:
Install the House-Wall Support
Fix either an aluminium track rail or timber ledger to the house wall depending on the selected design. Ensure all fixings are securely anchored into structural brickwork.
- Step 5:
Install Roofing
Cut roofing sheets to length and secure them according to the selected design. Polycarbonate roofing provides natural light, while metal roofing offers maximum shade and durability.
- Step 6:
Add Gutters and Drainage
Install guttering along the low side of the roof and connect downpipes to direct stormwater away from the storage area.
- Step 7:
Improve Flooring
Lay pavers or other outdoor flooring materials to create a clean, stable and well-drained walking surface.
- Step 8:
Add Storage Solutions
Install shelving, hooks, storage tubs or bike storage systems while maintaining a clear central walkway.
- Step 9:
Final Result
The completed side access storage corridor provides weather protection, organised storage space and year-round accessibility while making use of an area that is often overlooked.
