I’m repairing rotted out sections of framing around our bathroom and there’s a strip of metal flashing underneath the bottom plate that’s significantly deteriorated and will be removed. I can’t find anything in the NCC about needing a DPC for interior walls or walls surrounding a wet area so I’m not sure if I should replace it with something like Plascourse or install the new bottom plate directly on the slab.
Note: mould remediation is in progress. Mould remover has been liberally applied multiple times, I’m being very heavy handed with it as I have a sensitivity to mould and want the active spore count as close to 0 as possible. The slab is stained and the cement board is going to be replaced.
