I just purchased a replacement Mondella Kitchen Sink Mixer with the usual flexihoses
(cold and hot) - lengths are std 350mm.
Hot water fitted ok - pressure good - no leak.
Cold water a bit kinked with reduced pressure (and no leak). Have tried to minimise/eliminate kink but no luck. When I move the flexihose water pressure drops away entirely.
It appears hose is too long (probably need 200mm or 250mm to eliminate kink).
Does Mondella (or other suppliers) provide such hoses?
If not how do I get rid of this kink so pressure is normal (like the hot water side)?
Appreciate any advice.
