Can I attach the Wall art panels onto a brick wall in bathroom please
Hi @rayray
Unfortunately, your question is a little vague. what wall art panels to what type of wall and where in the bathroom (it makes a difference if you are thinking of drilling through the waterproofing membrane)? Pictures would help
Hi @rayray,
Assuming you are referring to the WallART panels such as this https://www.bunnings.com.au/wall-art-2400-x-1200-x-3mm-carrara-ice-wet-area-wall-shower-panel_p6660416 , then unfortunately, no they could not be installed direct to brick.
As per the Installation Guidelines, they must be installed either onto an approved flat substrate, such as cement sheeting, or onto a framework of timber battens. The guide also notes that all surfaces must be flat, square and dry before installation. Since brick walls are typically uneven and mortar joints create an irregular surface, they generally aren't suitable for direct adhesion of the panels.
I'd suggest checking out the discussion How to attach wooden battens to a brick wall to see what is involved.
Let me know what you think and if you would like some further help, please let us know.
Are the brick walls exposed brick or plastered?
