Trying to replace the valve in a 1970s bathroom shower tap. But the tap body does not have a hexagonal top and the tap body does not appear to have an internal square drive. See photos. How do you open the tap body to replace the valve??
Hello @mvdiy
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your tapware.
Please note that plumbing work needs to be completed by a licensed professional for safety and compliance.
I suspect that the spindle body is recessed deeper into the wall and is hiding the hexagonal section. I propose removing the patch cover on the wall if possible and using a https://www.bunnings.com.au/craftright-3-piece-tap-spanner-set_p0924472 . Please note that these pieces slot into one another allowing you to have a longer piece when using it over a tap spindle.
However, if after several attempts and the spindle will not come loose, I suggest engaging the services of a plumber to remove the stuck spindle.
thank you
