Hi Team,
Need some assistance to select the right product.
As you can see from the pictures, the two structures (living room and garage) were built at different times on separate foundations. A vertical separation crack running through an interior corner of a wall, visible both inside living room (beige wall) and outside (brick corner where the two brick types meet)
Over time they settle at different rates, pulling apart at the junction. This appears to be a control/expansion joint between two separate brick structures (house vs. garage).
Can you advise the right products to help the cracks interior and the garage.
Thank you.
