Hi, I have an old IXL 3 in 1 bathroom heat fan light that I want a direct replacement for. The old model number is CAT No. 12305
What model in the current IXL range would be a direct replacement and size to this one?
Thanks
Hi @BP22183,
The current equivalent would be the https://www.bunnings.com.au/ixl-tastic-sensation-3-in-1-bathroom-heat-fan-light_p4442470 .
It's designed to fit into the same ceiling cut-out area as many older IXL units. However, the newer unit has a slimmer and more modern profile, so depending on how the original fitting has weathered the ceiling paint, you may find that some touch-up painting is required around the surround after installation.
If you were looking for installers, we also offer a handy Heat Lamp Installation Service through Bunnings, which can take care of the replacement for you.
Thanks for much for this. Appreciate the quick and detailed response
