Hi Bunnings team,
I am looking to replace my old IXL 3-in-1 bathroom heat, fan and light unit (Cat No. 11303B, see photo attached below). The existing unit measures 253mm × 253mm, and the ceiling cutout is approximately 263mm × 263mm.
I have been recommended the following replacement:
IXL Tastic Original 3-in-1 Bathroom Heat Fan Light (SKU: p4442438)
https://www.bunnings.com.au/ixl-tastic-original-3-in-1-bathroom-heat-fan-light_p4442438
I understand the product's fascia dimensions are 345.5mm × 345.5mm, which is larger than my existing unit. Could you please confirm:
- The required ceiling cutout size for this model, and whether my existing 263mm × 263mm hole is compatible (i.e. does it need to be enlarged)?
- Whether the fascia plate will fully cover the existing ceiling opening without leaving any visible gaps?
In addition, could you please provide a quote for installation of this unit by a licensed electrician?
Thanks and regards,
Warren
