Hi all,
I’m planning a bathroom renovation in my 1983 home and I’m hoping to achieve a fully hobless shower and a flush transition from the hallway into the bathroom. I’ll be doing most of the work myself and bringing in a licensed electrician, plumber and tiler where required.
The bathroom has already been stripped back to studs and joists. My plan is to install 19 mm Secura flooring, a tile‑over shower base (still deciding which one), and a Hotwire under‑tile heating system. The shower will be 900 × 1200 mm, fully enclosed, with the shower rose and door on the 900 mm sides.
I have 36 mm available from the top of the joists to finish level with the hallway floor.
Proposed floor build-up
- Secura floor – 19 mm
- Waterproof membrane – ~2 mm
- Hotwire heating + self levelling encapsulation – ~4 mm
- Tile adhesive – ~5 mm
- Tiles – ~9 mm
This totals roughly 39 mm, so I may need to plane the joists by about 3 mm to achieve a flush finish. Joists are 95mm x 45mm hardwood.
Questions
- Are there any major issues with removing around 3 mm from the joists? I’ll need to plane them slightly anyway to level the subfloor.
- What tile‑over shower base would you recommend for this type of installation?
- If a tile‑over base isn’t recommended, what would be the best way to achieve a hobless shower on a timber floor?
Thanks in advance for any advice.
