Hi, I have a section of a 1.8m high rendered brick wall with columns spaced 2.7m that I want to mount the Ekodeck Castellated Panel onto. Total length is about 9m. I've already done a previous section as seen in the photo (at an increased height) but that was between two columns that was only circa 1m wide. I will need to put some timber supports between the paneling and the brick wall to support the horizontal timber - but the columns vary in depth between 100mm and 110mm. What is the best way to mount supports the depth of the columns, and what timber should I use to get a nice straight finish?
