Hello
I have some bench seating in my back garden. Rendered brick base with painted timber boards for the seating, which had weathered after many years.
In August last year I had someone replace and repaint the timber.
They purchased H3 Treated Pine decking from Bunnings, and used an oil based primer then exterior paint.
After one week, a sticky liquid started oozing out of patches in the timber. See pic1.
The oozing continued into early November then appeared to dry up. See pic2.
In mid November they came back and scraped the timber, sanded it back to bare wood, then reapplied two coats of oil based primer + exterior paint. Within one day bubbles appeared in the paint and continued to leak. See pic3.
I have left it several months to dry, and now the residue is more like the texture of old BluTak or chewing gum. See pic4.
It has been approx 10 months since the timber was initially purchased.
I have spoken to several people at Bunnings including timber and paint departments.
Some of the feedback was "I don't know", but the more credible feedback seems to be that the tannins/resin in the treated pine have been leaking out and causing these issues.
What is less clear to me is what I should do next. The suggestions include: Replace the timber; Scrape and sand back to bare timber; Use Cabots New Timber Prep.
No-one at Bunnings expressed any kind of responsibility for the performance of the timber, and apparently H3 treated pine is the right material for this work, so I don't understand was this a bad batch, did it need time to acclimatise, should my painter have done something different, or is it not fit for purpose?
At this point I don't want to keep throwing money at it and hoping for the best, and frankly I also don't understand why I should have to.
Appreciate if anyone has any experience, knowledge or advice they can share.
Thank you
