Hello there
Needing help to replace tap washer. Just done 3 successfully, but unable to budge last 2 spindles. Have tried WD40, not helping. Any suggestions?
Thanks in advance
Rell
Welcome to the Bunnings Workshop community @Garfield. It's marvellous to ahve you join us and many thanks for your question on changing a tap washer.
Can I ask what type of tool you're using to remove the spindle? Are you using a tap spanner, multigrips or a shifting spanner?
Would you also be able to upload a couple of photos of the tap spindle that you're trying to remove? That will give us a much better idea of exactly what you're working with and whether there are any signs of corrosion, scale build-up or damage. If you need a hand uploading images, please let us know and we'll be happy to assist.
At this stage, it sounds like the spindle may simply be seized in place. It's often worth applying WD-40 or a penetrating lubricant over a couple of days, giving it time to work into the threads before attempting removal again.
I'd caution against applying excessive force, as it's possible to damage the spindle, tap body or even the pipework behind the wall. If the spindle remains stubbornly stuck and you're not confident applying additional force, it may be worth engaging a licensed plumber to avoid causing further damage.
Looking forward to seeing some photos so we can provide more specific advice and please let me know if you have any questions.
Hello there Mitchell,
Thank you for your reply and please forgive the late reply. Elderly relative has just commenced palliative care.
Ok, I have used WD40 and hot water. I also put a great deal of pressure on it, which I won’t do again.
I have had a tiler here who has not finished, hence the disgraceful state of the tap.
Please see photos below
Thank you
Hi @Garfield,
Firstly, there's no need to apologise for the delayed reply. I'm sorry to hear about your relative's situation and wish you and your family all the best during what must be a very difficult time.
Looking at the condition of the tap, and given you've already tried WD-40, hot water and applied a significant amount of force, I suspect you've reached the point where it might be worth calling in a licensed plumber.
I've come across exterior taps before where the spindle had effectively seized into the tap body due to years of corrosion and mineral build-up. In some cases, they can become so firmly stuck that attempting to remove them risks damaging the tap body itself or even the pipework behind the wall.
Since you've already put considerable pressure on the spindle without success, I'd be hesitant to recommend increasing the force any further. The last thing you'd want is to crack the tap body or create a leak inside the wall.
A plumber may find it more practical and cost-effective to replace the entire tap assembly rather than continue trying to free the existing spindle. Once they can inspect it in person, they'll be able to determine the safest approach.
Please let us know how you go, and if you have any questions, we're always happy to help.
Hi @Garfield
Have you considered that it may be easier and cheaper to just replace the tap completely. Technically this is plumbing work but you would just be screwing one off and another on. Use 2 spanners (one to hold the wall fitting stationary and the other to undo the tap). Don't forget to use PTFE tape.
