Hello team
Tackling a job this weekend.
Our external french doors are binding in the centre in the red spots. I realise this may be as it has sagged a tiny bit, but I believe to be honest it was simply me not measuring quite right as this was one of my first DIY jobs about 5 years ago when I ordered this door kit from a joinery. The doors have always had the most tiny of gaps between them that a piece of paper barely fit into - i should have probably given myself some room to work with, but Ben of 5 years ago was not the Ben of now.
Anyway, I am totally strapped for cash and therefore cannot get a carpenter or builder out and need to fix myself.
Here are the problems I face.
- where the hinges join the jam is a solid timber frame, however behind the frame is brickwork (as the doors sit flush to the outside of the house which is brick veneer), so I cannot simply get longer screws as they hit bricks behind the frame. So simply "put longer screws in" will not work.
- the hinges are fixed pin so I cannot do the "just bend the hinges" trick either.
- the mortices are set at the correct depth, so I am unsure if I can simply put the mortices deeper or not. I also am hesitant to gouge more out of the mortices if that doesn't work.
- The fix needs to be done in a few hours, as having an external door open overnight etc just isnt an option for family safety and keeping my pets from escaping
My idea was to remove the door with the handle on it, and plane it down by say 3mm, re-mortice the hinge spots and re-mount it. This will give it some breathing room. I chose the one with the handle as you can see the let side already have a door lock that bolts into the frame above and if I move the door on that side the hole will no longer line up.
Can anyone that has door experience let me know if this will work. These doors are solid, heavy as hell, and too expensive to simply replace.
Thanks
Ben
