Has anyone epoxing on pepplecrete I like the finish but want to know if it can be done
Hi @paulynch,
Could you please provide a bit more information about the type of epoxy coating you're considering and the appearance you'd like to achieve?
The epoxy coatings I'm familiar with are typically designed to be applied over smooth concrete surfaces. Pebblecrete can present some challenges due to its textured surface and the resin binders used to hold the pebbles together. Depending on the product, there may be adhesion and compatibility issues, and the finish may not turn out as expected.
If you're able to share a photo of the Pebblecrete surface and a link to the epoxy product you're considering, our members will be in a much better position to advise whether it's likely to be suitable and what sort of finish you can expect. Please let me know if you have any questions.
