I have an old bare wood side table to use on my covered back patio. It's been out in the weather for years without rotting or anything (just stained green from some kind of growth but still solid) but I'd like to sand it and ideally paint it to make it look nicer.
I have various left over paints suitable but no primer and I don't want to spend any money (I would not buy this table in any state for $50, so I'm not going to spend $50 on primer + all the time & effort!). I don't care if it's not a perfect finish as long as it doesn't peel off or go funny straight away.
So I guess my options are:
a) do an undercoat (in lieu of primer) with white/light blue acrylic interior wall paint, then top coat of blue water-based enamel exterior/interior paint
b) do an undercoat (in lieu of primer) with white water-based enamel exterior paint, then top coat of blue water-based enamel exterior/interior paint
c) do an undercoat with white self-priming masonry exterior paint, then top coat of blue water-based enamel exterior/interior paint. The masonry paint is not meant for timber but it is self-priming. What would happen if I use it on wood? And can I paint over the top with water-based enamel?
d) Cabot's exterior varnish stain
e) Wattle Instant Estapol matt (rest of label unreadable due to rust. don't know if water or oil based!)
f) Cabot's gloss exterior clear polyurethane
g) I have a very old pot of blue "Natur" wood stain from Ikea but the label is illegible. I think this would need clear polyurethane on top
I'd prefer a top coat of blue paint to varnish in this case as I generally find paint is more 'forgiving' and lasts longer, and I like the pop of colour, but would it be a real disaster to paint without using any real primer? Although not ideal, are any of these options at all feasible
I also have an old tin of Fungishield. Should that go on first under paint or varnish? would it affect/limit what paint/varnish I put on top of it?
