Hi there,
I would like to ask for some suggestions on improving water flow on our roof gutter as pictured here, as it is causing water to seep and drip into the garage. The immediate below pictures are before I've installed
https://www.bunnings.com.au/fielders-2-4m-100mm-zinc-angle_p4790173
to cover the small gaps which is a suspect for the leak into the ceiling of the garage below.
These next few pictures will show the puddling issue which has caused as a result of the install above - I will take the pictures in the morning as it's currently raining and no lights.
How should I divert and / or provide enough gradients so that the water can flow into the downpipe?
thanks
