Hi @gulvir,
Luckily, there is a handy step by step guide on How to replace a tap washer, that will walk you through all the steps.
Have a read and let me know if there is anything you are not quite sure of. I can assist further if required.
I just want to know ,how to remove these tap handles. Which tool i will use. Otherwise i know how to change the washer.
Thanks,
The C and H buttons on the front of the tap are a cover. You can see there is a hex head around them in the chrome. To remove the cover, I am assuming based on this fact that you need to rotate them counterclockwise, using this chrome hex head to grip them, to remove the caps.
You should be able to use a tap spanner or adjustable spanner to do this. Once those covers are off, you should be able to simply pull the tap handle off.
