Hi, I've just had a new cypress pine picket front fence installed. The installer told us to wait at least 6 weeks before painting to allow it to season. In terms of preparation/painting, I'm looking for some guidance. The plan is to do a light sand, particularly where the nail/screw holes are, then to prep/fill the nail holes, and the prime and paint the fence with Dulux Weathershield.
Some things I'm not sure on: with the sanding, what grit is recommended? Do you need to prime the nail holes, then fill it, then prime again? What filler is recommended? Should the primer be oil based or water based? I did see a suggestion somewhere that oil based is better, and can still paint Weathershield over it.
The plan is to paint with a roller and brush for the gap (only 20mm).
There is also a steel frame on the back of the gate. I understand that will need to be painted with metal specific paint.
Any tips/suggestions greatly appreciated!
