Hello! My bath plug has come loose and I can pull the whole assembly out of the hole. I can see the large rubber doughnut seal and the pipe inside the drain, but it seems to be sitting too low. I can put the plug back in, but the doughnut seal is loose and not sealing properly.
I’m thinking I may need to lift the pipe and rubber seal up toward the underside of the bath so the seal sits flush against the hole, then reinsert the plug assembly to hold it all together. The problem is that the white three-prong plastic piece has snapped, and I can’t find a replacement at Bunnings.
Could anyone please tell me:
A. Whether I’m on the right track.
B. What product I need to replace it.
C. Whether I can use a chrome pop-up basin waste from Bunnings, or whether it needs to match my existing fixture exactly.
Any help is very much appreciated!
