I'm planning to diy landscaping my backyard with retaining wall and garden beds, I've consulted a lot with Gemini but I'm not pro enough to see if its giving me bad advice.
A landscaper originally suggested building a new retaining wall directly against our existing boundary fence line (which sits on top of an existing concrete retaining wall). I am uncomfortable adding lateral soil weight to that boundary structure, so my solution is to move the new retaining wall 500mm away from the fence, and turning the gap into a raised planter box, leaving 50mm air gap to the fence.
The details: One side of the garden bed is facing the lawn and acting as the retaining wall,
Total 9.6m length, two row of sleepers (200x50mm) total of 400mm height. Post between 1.2m lenght of the retainer (total of 9 posts - orange color). Im thinking of using 200x50x800mm as the post (same material as the retaining wall, 400m deep with concrete footing)
The other side of the garden bed is facing a fence. Since this fence is also sitting on a concrete retaining wall, I'm not digging post on this side of the garden bed, and will be leaving 50mm gap to prevent adding weight to the fence. Instead, I'll put connecting timber between the main retaining wall and this side (light green color) for each post. I'll also add a timber connecting the sleeper timbers (yellow).
Total width of the garden bed 500mm (with 400mm internal)
Please advice what's wrong with this, and if it's diy'able (from a novice woodworker/cabinet maker background pov)
Thank you all!
Entire backyard is 13.5m
