I've moved into a unit that has nowhere to connect a washing machine so I'm looking to connect the washing machine to the kitchen sink's faucet.
After removing the fitting at the end of the faucet I find a ~24mm fine thread on the inside (image 1).
The washing machine has 2 inlets — hot and cold — but I believe that I can connect the faucet to just the cold inlet but turn the hot water on from the faucet. Does that sound feasible?
The washing machine's hoses have ~27mm threads at both ends, and the threads are quite chunky (image 2).
Bunnings' website suggested I try the "Kinetic Aerator Adaptor Kit" so I purchased that. I hadn't measured the washing machine's hoses at that point but once I got home it was clear that there was nothing in the kit that would connect directly from the faucet to the washing machine.
But it did look like it might perform maybe half of the bridging operation.
The brass-coloured part (second part in image 3) has a matching ~24mm fine thread on one side so it fits into the faucet, and that then gives me a ~22mm fine thread on the other side of the same part.
The other 2 chrome-coloured parts from the kit (parts 3 and 4 in image 3) both connect to that ~22mm thread giving me two more output options from the faucet. So I have three output options in total:
1. the ~22mm fine thread from the brass part.
2. the ~20mm chunky thread from the first chome part.
3. the un-threaded connection from the second chrome part.
Q1: is there a part that I can buy at Bunnings that will connect to one of those three outputs to the ~27mm input of the washing machine hose?
Q2: if not, can you see a way to connect from the faucet to the washing machine?
Q3: does connecting the hot output from the faucet to the cold input of the washing machine (since there's only one output from the kitchen sink) sound like the right approach?
Thanks!
Rowan.
