I took this tired, scratched, water-damaged set and refurbished them to look brand new. I cleaned them off, stripped the finish, sanded back the damage, and applied varnish.
Orbital Sanding Disc Set -
https://www.bunnings.com.au/ryobi-30-piece-125mm-orbital-sanding-disc-set_p0988011
Sandpaper roll -
https://www.bunnings.co.nz/flexovit-timber-sandpaper-roll-115mm-x-5m-120-grit_p1210470
Kwik Strip
Wood filler -
https://www.bunnings.co.nz/timbermate-250g-rimu-wood-filler_p1563609?store=9476&gclsrc=aw.ds&gad_source=1&gad_campaignid=21878343039&gbraid=0AAAAADL7rPoXAd_9cuB9oRPX7Nk1d-bbU&gclid=CjwKCAjwgO7RBhBKEiwAZNP85hY9fdvQIarK9PUNOPCf0D90I6l6bhdTkvTINHr7y84WDW46hOOKyRoClq8QAvD_BwE
Polyurethane -
https://www.bunnings.co.nz/cabot-s-500ml-satin-oil-based-cabothane-clear-timber-varnish_p1522083?store=9476&gclsrc=aw.ds&gad_source=1&gad_campaignid=21878343039&gbraid=0AAAAADL7rPoXAd_9cuB9oRPX7Nk1d-bbU&gclid=CjwKCAjwgO7RBhBKEiwAZNP85hxPYpwD3ZsJXvCsbT-ScqC-CAOppYgSl1J16WOt25pecE6NKjOMkBoCM3EQAvD_BwE
Random orbital sander
Plastic scrapers
Paint brushes
Screwdriver
I began the project by removing the handles and cleaning every inch of both pieces with warm soapy water.
- Step 2:
I applied multiple coats of the paint stripper to remove the peeling, yellowed finish. I scraped the stripper off using plastic scrapers and cleaned off any remaining chemicals with a cloth and warm, soapy water.
- Step 3:
Once dry, I went in with my random orbital sander. I started with 80 grit on some particularly stubborn scratches, before moving up to 120 grit, then 180 and finishing with 240. This took hours, but the result was a buttery smooth finish.
- Step 4:
Halfway through the sanding process, I found some stubborn grooves that weren’t just going to sand away. I used wood filler on those places, applying with my hands and scraping flat with a metal scrapers
- Step 5:
I vacuumed all the sawdust off and used a microfibre to ensure there wasn’t anything left on the pieces. Then, I applied the polyurethane. I did two coats of this.
- Step 6:
I finally used a brown paper bag to “sand” the pieces once the polyurethane finish. This left the wood feeling so smooth to the touch.
- Step 7:
I cleaned the handles with warm soapy water before reattaching them. And just like that, the project was done!
