We had a new deck and seating installed. Due to the height of the seating I had to make a table to match as all current table were too low. It came up a treat with enough seating for 10 people. I also made a long stool to match.
18mm Marine Ply for top
125mm x 125mm laminated pine posts
90mm x 45mm laminated pine posts
Circular saw
Triton work bench
Router
Spade bit
Drills
Screws
Wood Glue
Legs.
Cut timbers and checked out mortise and tenon joints.
Glued up each set of legs.
Aligned all 3 sets and then checked out the 2 x long pieces to stabilize the table.
Glued and screwed the 2 x long pieces into place.
Cut 2 x diagonal pieces for strength.
Glued and screwed these into place.
Cut timber top and screwed onto frame.
Filled all holes with wood filler and coated with clear lacquer.
