If your workshop is anything like mine, scrap timber has a habit of taking over which is why I decided to build a compact Scrap Wood Storage Cart that's designed specifically for small workshops, making it easy to keep offcuts organised without sacrificing valuable floor space.
Built on heavy-duty wheels, the cart can be rolled anywhere around the workshop when needed, and it also includes handy storage for my screw boxes plus a compartment for all those small offcuts that are too good to throw away but always seem to end up underfoot!
Best of all, the cart was designed to complement my French Cleat Wall System, making it the perfect addition to my ongoing workshop upgrade.
17mm Formply:
https://www.bunnings.com.au/specrite-1800-x-1200mm-17mm-formply-f17_p0390220
30m Pinnacle Black Screws:
https://www.bunnings.com.au/pinnacle-4-x-30mm-black-countersunk-timber-screw-200-pack_p0201374
100mm Heavy Duty Casters:
https://www.bunnings.com.au/easyroll-100mm-150kg-blue-rubber-heavy-duty-swivel-castor_p0073909
12" DeWalt Mitre Saw:
https://www.bunnings.com.au/dewalt-305mm-corded-compound-mitre-saw-w-stand-dws780-xe_p0441385
10" DeWalt Table Saw:
https://www.bunnings.com.au/dewalt-254mm-2000w-corded-table-saw-dwe7491-xe_p0274900
Makita Trim Router:
https://www.bunnings.com.au/makita-18v-brushless-laminate-trimmer-drt50z-skin-only_p6240437
Makita Drill:
https://www.bunnings.com.au/makita-18v-brushless-heavy-duty-compact-driver-drill-ddf484z-skin-only_p6240421
Clamps:
Empire Speed Square:
https://www.bunnings.com.au/empire-180mm-laser-etcher-rafter-square-true-blue_p0154654
Tape Measure:
https://www.bunnings.com.au/stanley-8m-tape-measure_p5660379
Attach the feet supports to the base for the wheels:
- Step 2:
Attach the first side to the base:
- Step 3:
Attach the back of the unit to the base and the side:
- Step 4:
Screw the other end to the base and the back piece.
- Step 5:
Attach the middle support piece and start on the shelving.
- Step 6:
Finish off the shelving and attach the front of the wood storage box.
- Step 7:
Attach the piece to the front of the top shelf to stop stuff from sliding off the the shelf.
- Step 8:
Attach the piece to the back of the unit to stop material from sliding off the back.
- Step 9:
Attach hooks to the back of the unit which will be used to attach occy straps.
