This old bookshelf was a dumping ground for anything and everything & always looked messy even after trying to tidy it. So I decided to up-cycle it and couldn’t be more happy with the way it turned out!! It’s now a calming feature in our home rather than the stress zone it previously was.
3 mm MDF sheets
Primer
Topping Compound
Liquid nails
No more gaps
Paint
Battery operated downlights
Baking Soda
Wide Pine plank
Brown soft wax and Limed Wax for the pine
Ryobi Jugsaw
Ryobi Nail Gun
Plastering scraper
I placed sheets of MDF against the unit and drew my template around each box then, using a jigsaw, I cut out my template. I then attached the mdf using liquid nails and some hardwood nails using my Ryobi nail gun.
- Step 2:
I then primed using Zinsser primer & no more gaps to fill in any joins before covering the unit in topping compound. I also decided to add some wooden boards in random boxes which I made from pine.
- Step 3:
Once dry, I sanded all over using a mix of 120, 180 & 240 grit sandpaper, then painted it light tan Matt. I also added a backing board. To add some texture I added baking soda to the paint and then brushed it on with a rough criss-cross stroke. I also added some battery operated downlights to some of the boxes. To make the pine boards look more like hardwood I used a browning wax followed by a Limed Wax.
