Hi , How to get rid of this brownish stain behind this tap ?
Thanks.
Hello @nigelfds
I suspect that this is caused by calcium deposits from water sitting too long in the same place. I propose trying out a calcium remover such as https://www.bunnings.com.au/clr-750ml-ready-to-use-calcium-lime-rust-remover_p0356353 . I suggest spraying it directly on the basin stain and letting it sit for a few minutes before scraping it off with a https://www.bunnings.com.au/scotch-brite-155-x-100mm-heavy-duty-scourer-pad-6-pack_p4460588 . Please do not use anything that will damage the surface of the basin such as steel wool or metal scrapers.
Please remember to wear personal protection such as gloves and goggles.
