Hi there!
I have an issue - we've installed Linea (Hardie) weatherboard - and have used their corner pieces for the corners - but they look absolutely awful - I can see gaps - and can't get in there with gap filler (especially at the bottom of the gap where the gap is the most narrow).
I really don't understand why the Hardie Linea Weatherboard installed with the Hardie corners looks so bad!
How should it be?
I think I recall seeing that sealant wouldnt be needed or shouldnt be used (to allow water out) at these joins - but when painted white - and the gaps being 'black space', they're so visible!
If you think the weatherboard should have been cut a bit longer, it can't have been - as it has to slot in behind the lip of the corner piece, The corner piece also must be installed first. When I look at other homes it always seems as though the corner is something that goes on last. ???
This will be an outdoor seating area so will be right in view! :-(
Please help - or describe what we should have done.
The first 2 pics are where I've used the proper flexible sealant and painted (sikaflex something). The can see I cant get the nozzle or my finger right to the bottom).
The last 2 pics are where I've left it un filled and there's a gap.
