When my husband said he’d love a coffee machine, my first thought was, “Where is it going to fit?” Our small kitchen didn’t have the bench space. But it did have an empty corner that wasn’t used and had a power point. So I built a vertical coffee bar that gave us a functioning coffee nook without sacrificing workspace. Now he has the coffee setup he wanted, and I made use of a space that had been completely wasted.
Coffee bar materials
Liquid nails
https://www.bunnings.com.au/selleys-320g-liquid-nails-construction-adhesive_p1233751
Kaboodle cabinet 400mm
https://www.bunnings.com.au/kaboodle-400mm-white-base-cabinet_p2662599
Wall slats
https://www.bunnings.com.au/20-x-5mm-2-4m-tasmanian-oak-round-edging_p0083832
Peel and stick tile
Gallery rails
Bench top
Shelves
https://www.bunnings.com.au/porta-140-x-40mm-1-2m-general-purpose-pine-dressed-board_p0117158
Walnut stain for shelves and bench top
https://www.bunnings.com.au/bondall-250ml-antique-walnut-monocel-wipe-on-gel-stain_p0938643
Clear protective coat
https://www.bunnings.com.au/cabot-s-500ml-satin-oil-based-cabothane-clear-polyurethane-timber-varnish_p1522083?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB969T_BEvMnGh-Oz7fqc8UH6&gclid=CjwKCAjw6f3RBhApEiwAMaCqWQRYlfGPVNaeEaReEMQvXh1rQFIIo2lKXBUj9CZhHUQPEUCAmEztJxoCskQQAvD_BwE
18mm Plywood door
https://www.bunnings.com.au/1200-x-596mm-18mm-plywood-pine-bc-grade_p0390159?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB_1oHe-RWJlj8j_I-Q4RYMiI&gclid=CjwKCAjw6f3RBhApEiwAMaCqWf9mdTUOdVE8M6pQNm8kC4mFdaCkGEN_v18Mksl641YskVxyTxubIxoCyjMQAvD_BwE
Door hinges
https://www.bunnings.com.au/blum-110-soft-close-full-overlay-hinge_p4160514?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB_1oHe-RWJlj8j_I-Q4RYMiI&gclid=CjwKCAjw6f3RBhApEiwAMaCqWTC7YewDreJQDVljMz3H2jA9mTd7-EdWrjBMXSvCYkTTudv5WAMpdhoCYxsQAvD_BwE
Paint “pleasant hill”
https://www.bunnings.com.au/british-paints-white-semi-gloss-h2o-enamel-paint-500ml_p1420575?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB969T_BEvMnGh-Oz7fqc8UH6&gclid=CjwKCAjw6f3RBhApEiwAMaCqWasJtFeMDF5J4-PICGsWjfjzKUh8k9eM-YEvjmWv0esVVFSOjXSushoCNSsQAvD_BwE
Primer
https://www.bunnings.com.au/dulux-1l-precision-white-maximum-strength-adhesion-primer_p1400848?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21119565770&gbraid=0AAAAADtbEB969T_BEvMnGh-Oz7fqc8UH6&gclid=CjwKCAjw6f3RBhApEiwAMaCqWW2D8PnFZeD2FIdQ82PD0x26kCNJksPDU-DvrCkHdTQtzvuSObUTOxoC-u4QAvD_BwE
Coloured gap filler
https://www.bunnings.com.au/monarch-240g-brown-mini-gap-filler_p1662438
Coloured gap filler
Coffee Bar tools
Measuring tape
https://www.bunnings.com.au/stanley-8m-control-lock-tape-measure_p0400603?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB_0ukJqKFKrC2f6GxHuTiWQK&gclid=CjwKCAjw6f3RBhApEiwAMaCqWXoChhl2OBjcAJpnt1gVMLSP4Hb9Ow4su2KqQAFt6qE1rwzvuOHNZBoCCRYQAvD_BwE
Pencil
https://www.bunnings.com.au/bunnings-carpenters-pencil_p1036370
Level
https://www.bunnings.com.au/empire-225mm-magnetic-torpedo-level_p5663825?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB_0ukJqKFKrC2f6GxHuTiWQK&gclid=CjwKCAjw6f3RBhApEiwAMaCqWSHQzolyDVQJCmAkDbyxVOec_6VoiqEBE2A7uZi3aJBMr_twOLJToBoC-4AQAvD_BwE
Sander
Circular saw
https://www.bunnings.com.au/makita-185mm-7-1-4-1200w-circular-saw-hs7000sp_p6240318?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB_0ukJqKFKrC2f6GxHuTiWQK&gclid=CjwKCAjw6f3RBhApEiwAMaCqWUcuWv_qVrrc8mVHSyAQGYn9mps5zIKOdV3eQvjTo3elw76nI9He5BoCOlMQAvD_BwE
Drill
https://www.bunnings.com.au/makita-18v-mobile-brushless-4-mode-impact-driver-dtd154z-skin-only_p8901067?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB_0ukJqKFKrC2f6GxHuTiWQK&gclid=CjwKCAjw6f3RBhApEiwAMaCqWfVK07gwYjty7by6ZrcC-Mlyy9zB7NzHSrPrbahvD68E4MJ7OQOp7RoCEBUQAvD_BwE
Kreg hinge jig
https://www.bunnings.com.au/kreg-concealed-hinge-jig_p0202868?store=8172&gclsrc=aw.ds&gad_source=1&gad_campaignid=21118986128&gbraid=0AAAAADtbEB_0ukJqKFKrC2f6GxHuTiWQK&gclid=CjwKCAjw6f3RBhApEiwAMaCqWYsAhkanoF60nPJr6jqAtTw1CGHEBbhn-z2_zVLXEyyIk-EynME3lxoC-kAQAvD_BwE
My space was only 370mm wide and unless I went with a custom cabinet I couldn’t find one to fit perfectly so I got a 400mm wide Kaboodle base cabinet and customised its size by cutting the base, shelf and top support bar down. Before building the base cabinet and slotting it into the coffee nook.
- Step 2:
I painted the wall green and for the shelves I banged them up using a hammer, grinder and hand saw to make them look rougher and older. I cut the shelves to size along with the bench top. Next I stained the shelves, bench top and wall slats in antique walnut before sealing them with a clear coat to protect them.
- Step 3:
Step 3 was attaching the bench top to the cabinet and installing the peel and stick tile to the splash back.
- Step 4:
Following step 3 I attached the gallery rails I got online to my shelves and installed the wall slats using liquid nails, a level and a skinny piece of wood to act as a spacer so they were evenly spaced out.
- Step 5:
Because my cabinet was a custom size I needed to build a door to fit my space. I used 18mm ply and measured it to be a full overlay style. I used my circular saw to cut it to size then sanded the front and back along with sanding the edges and corners to be slightly rounded then I drilled the holes for the handle. Next I used the kreg hinge jig to drill the holes for the hinges. I then primed and painted my new door, installed the hinges, handle and installed the door on the cabinet.
- Step 6:
Step 6 had me cutting, priming, painting and installing the kick board. I also got the shelving brackets in the post so I installed the shelves using my mini level to ensure they were level and not wonky.
- Step 7:
My next step was to gap fill the sides of the benches and peel and stick tiles.
- Step 8:
Lastly it was time install hooks under the bottom shelf for cups, place the coffee machine and stage the shelving with a beans canister and decor
- Step 9:
Take a step back and admire the space created!
