Hi. I have a molded swing slide climb brand slide made from polyethylene plastic attached to a cubby house. I've noticed a crack has appeared at the top where I've attached it to the cubby. Photo attached. Any ideas for a repair? cheers
Pete
Hello @peterepeat
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your play slide.
Looking at the picture you posted, it appears that some other adhesive was applied to the surface of the crack. I suggest removing all of the old adhesive first before applying the new one on the damaged section. I recommend looking at either the https://www.bunnings.com.au/selleys-all-plastics-super-glue_p0212331 or the https://www.bunnings.com.au/loctite-2g-and-4ml-2-part-all-plastic-superglue_p1210073 . They are designed to go on polypropylene plastics.
My best advice is to prepare the surface very well and to strictly follow the application instructions. Please make sure not to use too much pressure when squeezing the tube containers. Generally speaking, I suggest taking the slide off from the play structure so that you can properly apply the adhesive to the damaged section. I propose using a ratchet strap to bring the damaged sections together and allowing the adhesive to fully cure at least 24 hours or more for full strength.
Please remember to use personal protection such as gloves and goggles when handling the adhesives.
Hi @peterepeat,
Given the slide appears to be relatively new, I'd encourage you to take it back to the Bunnings store where you purchased it and speak with the team to see whether it can be replaced under warranty.
I would be hesitant to recommend attempting a repair in this case. The crack is located right at one of the mounting points, which means the structural integrity of how the slide is secured has been compromised. Even if the crack could be glued or plastic welded, there would always be a risk that the repair could fail under load.
When it comes to play equipment, it's simply not worth risking the safety of your children with a repair that may not restore the slide to its original strength.
Please let us know how you go with the store, and if the slide is no longer covered by warranty, we'd be happy to discuss replacement options with you.
