Using the Bunnings Online Kaboodle portal to design and estimate total costs, this design/costing tool enabled us to perfect our vision whilst keeping within budget. Bunnings professionals liaised with us at the special order desk and arranged a consultation for a measure at the house to iron out any mistakes in measurements or products before we ordered. We had the most fun ever putting all the cabinets, benchtops and accessories together and painting the room for it's complete makeover. The final result from the Bunnings range is above and beyond our original expectations and we are absolutely thrilled.
Kaboodle Cabinets
Kaboodle White Gloss Doors
Kaboodle end panel fillers
Kaboodle Aluminium kickboard
Mirostone Benchtop
QEP 3mm Cross Tile Spacers - 100 Pack I/N: 6821850
Tile glue
Dunlop 1.5kg Flexible Coloured Grout - Magellan Grey I/N: 0281256
Dunlop 310ml Magellan Grey Coloured Silicone I/N: 0281553
QEP 8mm x 3.0m Silver L Shape Angle Tile Trim I/N: 6650055
Dulux 4L 1Step Prep Primer, Sealer & Undercoat I/N: 1370234
Dulux 4L White Ceiling +PLUS Kitchen And Bathroom Paint I/N: 1370220
Dulux 4L Vivid White Semi Gloss Wash&Wear +PLUS K & B Interior Paint I/N: 1370132
Zinsser B-I-N Primer Sealer Stain Blocker - White 3.78L - 3.78L I/N: 1565677
Sandleford 25mm Black rod I/N: 0022303
Sandleford 25mm Black rod fitting round flange I/N: 0011382
Practa 60x150cm white 25mm Aluminium Venetian I/N: 0513542
Adoored Satin Chrome Rectanle Rubber Bumper Door stopper I/N: 3961342
Aquachek plasterboard wet area
Builders Edge 75mm Plasterboard Jointing tape I/N: 0730321
Gyprock plaster mud coats
Hume Prima Ceramic Tile Underlay 1800 x 900 x 6mm 1.62sqm I/N: 0710334
Paslode 30 x 2.8mm 2kg Galvanised Fibre Cement Nails - 1200 Pack I/N: 2360506
Ryobi 18V ONE+ cordless jigsaw I/N: 0488988
Ryobi 18V ONE+ HP Brushless High Torque Hammer Drill RPD18X1I/N: 0919294
Ryobi 18V ONE+ 127mm HP Brushless Tile And Masonry Saw I/N: 0437502
Ryobi 18V ONE+ Caulking Gun I/N: 0385366
Ryobi 18V ONE+ Clamp Light I/N: 0359139
Ryobi 18V ONE+ 216mm Sliding Mitre Saw I/N: 0165564
Paint brushes
Paint rollers/stick handles
spirit level
Crescent Lufkin 10m x 30mm Shockforce Tape Measure I/N: 0172740
Bosch Professional 10m Cross Line Laser With 1.5m Tripod I/N: 5660718
Ozito PXC 18V Drywall Sander PXBDWS-225 I/N: 0540053
trowels for tile glue/grout and plaster mud
Remove old wall linings to prepare for Plumbers and Electricians to remove old fittings and create area for new connections.
- Step 2:
Add new wet area plaster, glue and screw, fit cornice and finish plaster with plaster tape and mud using trowels. After drying sand using various cordless ozito plaster finish sander.
- Step 3:
Stainblock existing hardwood window and door surrounds and then paint ceilings and walls architraves using dulux primer, sealer and wet area paint and gloss for the architraves. Lay and fix cement sheeting on floor.
- Step 4:
Put all cabinets and end panels together and fit to wall using ryobi cordless drill. We created a support rail screwed to the wall to support the weight of the overhead cupboards whilst lifting and fitting.
- Step 5:
Add kickboard and benchtop.
- Step 6:
Cut the Mirostone benchtop sink cutout space using normal wood cutting tools such as the Ryobi cordless range. Call back plumber to fit sink and taps and Electrician for fit off.
Fit tiles to wall using tile glue and spacers and then measure, cut and fit aluminium edge ready to grout and silicone. Tile floor and skirts, glue/grout.
- Step 7:
Measure and cut black hanging rail, fit between end hanging cabinets/wall and screw in using screws supplied with rod flanges.
- Step 8:
Add doorstop to newly painted door and add blind to door plus the window blind to complete the new look room which is nearly identical to the Bunnings Kaboodle design plan below.
