built arbor, path, pavers and garden to enhance the appeal of the house and identify where front door was.
200 * 42 * 6000 H3 treated pine (pre primed)
3000 * 100 H4 posts
125 * 12 mm galvanised cup head bolts, washers and nuts
100 mm galvanised stirrups (Qld rated)
Undercoat and primer
Gloss white deluxe
Post hole cement and general purpose cement
Cracker dust
Pavers
Coral stone
string line , circular saw, drill and drill bits, pencil, tape measure, laser level, spirit level, excavator, compactor, clamps, shovel, crowbar, cement mixer, paint brush, hand saw.
draw up a plan
- Step 2:
excavate the area and set post locations and plan garden edges
- Step 3:
fit garden edges, compact down the paver base, lay pavers and dig arbor post holes
- Step 4:
position the stirrups, confirm levels and square and cement in position.
- Step 5:
fit prepainted and rebated posts to stirrups and confirm orientation for crossmembers.
Fit precut and painted crossmembers with crossmember stainless noggin stays.
drill cross member to post 1 and measure and adjust post 2 to plan. Fit crossmember 2 to post 3 and 4 as per cross member 1. Check levels and measurements.
fit 6 cross members to stainless noggin stays with clout tacks and self drill screws.
paint and touch up.
- Step 6:
fit coral stone between pavers and lay premium garden soil and plant hedge fitting off with mulch. Clean and tidy up.
