Original fence was just a makeshift fence for short term made out of black bunnings stakes & chicken wire. I took it upon myself to make something a bit sturdier & long term. Wanted something more fitting to the property so I decided to go wooden farm style fence.
- Orbital sander - Ozito PXC 18V Random Orbital Sander Kit PROK-200 - Bunnings Australia
- Belt Sander - Ryobi 800W 76mm Belt Sander - Bunnings Australia
- Ozito Drop saw - Ozito 1600W 210mm 8¼" Corded Compound Mitre Saw - Bunnings Australia
- Ozito Circular saw - Ozito 185mm 1300W Corded Circular Saw - Bunnings Australia
- Ozito Jigsaw - Ozito 680W Pendulum Jigsaw With 3 Blades JSW-6800 - Bunnings Australia
- Hammer Drill - Ozito 1500W 5J Rotary Hammer Drill Kit RHD-1550 - Bunnings Australia
- Tensioner - PEAK Chain Link Fencing 810mm Galvanised Vinyl-Coated Steel Fence Stretcher - Bunnings Australia
- Made a list & did about 4-6 trips to bunnings to collect the materials 😅
- measured up the distance & cut all the post to size
- Dug out the rock/clay & cemented the posts in
- Notched all the posts for the slats top & bottom
- Cut to length & fit slats between posts
- Made up gate frames & secured to posts using hinges & brackets
- Sanded the entire fence ready to be stained
- stained the entire fence with 2 coats to ensure it was protected
- Secured the mesh on one end of the fence & tensioned it around & working my way around fastened it to the post/slates
- The proceeded to do the same for the gates located on each end of the fence
