Travertine tile crazy paved coffee table with knockdown textured render
M12 75x35mm treated pine, clout nails, 30mm stainless screws, villa board, sikaflex, render beading 2.5mm, render, Resene Paint, Waterbased silkopel sealer and much more
Every single tool in my shed!
Concept & Design
Sketched the initial concept with a focus on clean architectural lines, balanced proportions, and a monolithic appearance.
Structural Frame
Built a reinforced frame from M12 treated pine (75 × 35 mm), using screw-and-nail construction with 200 mm internal bracing for rigidity.
Cladding
Clad the frame with 6 mm fibre cement (Villaboard), creating a stable substrate suitable for a render system.
Edge Reinforcement
Installed render beads to all external corners and embedded fibreglass mesh into the render system to improve strength and minimise cracking.
Base Render
Applied a Rockcote Quick Float base coat to establish the shape and create a smooth, consistent surface.
Architectural Texture
Finished the exterior with Rockcote Coarse Texture, hand-worked to achieve the artisan render finish.
Stone Installation
Hand-laid individual travertine pieces in a crazy-pave pattern using a polymer-modified white-set tile adhesive.
Grouting & Sealing
Grouted the stone with Ardex WJ50 White Grout before sealing it with Silkopel WB Stone Sealer for long-term protection.
Architectural Coating System
Primed the rendered surfaces with Resene LimeLock, followed by two coats of Resene Lumbersider Low Sheen in Wattyl Arrowwood.
Full 2 part series is on the allthingsexterior youtube!
