This project pushed me well outside my comfort zone as it was the first time I’d built a yoga chaise from scratch. I had to learn new construction and upholstery techniques, overcome design challenges and make adjustments along the way to achieve the shape and comfort I was aiming for. Through patience, problem solving and plenty of determination, I transformed an idea into a finished piece that is both practical and visually striking. Completing it gave me confidence to take on more ambitious projects in the future.
Plywood, pallet timber, brad nails, foam adhesive, foam sheet, upholstery edging rail, faux leather, staples
Ryobi jigsaw, Ryobi brad nail gun, Ryobi reciprocating saw, staple gun, scissors
first I had to work out the design which ended up being harder than I expected because I had to figure out a comfortable curve
- Step 2:
I then cut out my design and nailed the reclaimed timber support in to place
- Step 3:
I then used a thin piece of plywood and wet it with water to bend it into shape so the foam had a flat surface to stick to
- Step 4:
I then used adhesive to glue a foam sheet to the chaise
- Step 5:
I then cut my fake leather to size and attached it using a staple gun, ensuring to stretch it to form a good fit
- Step 6:
I then used some thin padding foam on the sides before attaching the side leather panels using an upholstery edge strip. Finally I added some feet to the bottom to raise it off the ground.
